Can a Smart BMS 12/200 load and charge disconnect a Quattro 5000? The manual says it can do so for a Multiplus but no mention of Quattro. Thanks
Yes it can, the same way as the Multi of the same rating (e.g. MultiPlus 24/5000 and Quattro 24/5000). The Quattro is a MultiPlus with double AC input.
Stupid answer, the Smart BMS 12/200 is only for 12V systems, not 24V. So it can work the same way for Multi or Quattro 12/5000.
54 People are following this question.
