rikschamax avatar image
rikschamax asked
GridAssist only
Hello.
I am using a SmartSolar 48/3000/35 and 10kWh LiFePo4 batteries.
How can I use GridAssist as it is described in HUB2v3 without using that assistant?
The assistant doesn`t work. I think because I have a stand alone BMS. With that assistant you can`t choose "any LiFePo4 battery with own BMS" as in ESS assistants.
Thanks.
grid
