kevinpng avatar image
kevinpng asked
MPPT setting for solar battery
Greetings
I have a SmartSolar MPPT 100/30 and I have just bought a Solarpawa deep cycle gel battery.
DC250-12 (12v250AH/10HR)
Standby use: 13.5-13.8v
Cycle use: 14.4-15.0v
What would be the best settings on the MPPT for this battery.
Thanks for your help.
Kevin
on a beach in Papua New Guinea
battery
kevgermany avatar image
kevgermany answered ·
Use either of the two deep discharge settings. That's 1 and 2 if you use the rotary switch.
The makers comments translate to absorption and float.
So you can manually set values in the ranges they give I'd you wish
