graveyphil avatar image
graveyphil asked
MPPT 100/20 will load be able to be used to top up another battery
i have connected the load via an anderson meter to a spare 130A/H lead carbon battery that conveniently fits in an unused cupboard with a 450w 12 v inverter i use to charge my computer, ebike and golf battery... these photos were of todays 'test' without load on the inverter... If this works the biggest load would be a small compressor freezer 3.2amp... Panels are 2 x 140w [more than 10 years old] and batteries 2 X 240A/H lead acid [5 years and were struggling before installing a dc/dc engine battery charger
... this was not a great sunshine day....both app and meter showing similar amps and volts... what will the max voltage be from the load???
extra charging from motor = 50 amps to house batteries
MPPT Controllersbattery charginginverter current draw
@gravey.phil
I am not completely understanding your question what will the max voltage be from the load???
How has your load output been configured?
In the each option there is a voltage range defined except the option for always on. As far as I am aware it can only go as high as your system battery does.
graveyphil answered ·
i am just using the default setting... will the load voltage match the voltage being sent to my RV batteries?
peter-3 avatar image
peter-3 answered ·
Yes I think they are the same voltage .
