peter-3 avatar image
peter-3 asked
MultiPlus Password ?
From my previous question :-
Reversed UPS on Victron Energy MultiPlus ? - Victron Community
I've looked at the Demo products and found it is possible to do what I want , BUT it looks like even setting the battery type is protected by a password looking it videos .
Is this password just a formality ? if not this product is totally useless and looks like I should get the phoenix inverter or is that password protected too ?
Alexandra avatar image
Alexandra answered ·
@peter@peter247.co.uk
It is in the manual. To change basic settings and update firmware with Victron Connect is zzz. It does prevent accidental changes.
The only other thing that will need a not shared password for reglation reasons is the grid code setting. But you don't need to set that for basic AC ignore reasons.
peter-3 avatar image peter-3 commented ·
Thank you , that puts my mind to rest .
If I can change all the setting like get it work on life batteries etc , fine by me .
I DON'T WANT IT TO FEED ANY ENERGY TO THE GRID , just use the main for backup power and panic charging .
Didn't see anything in the on-line manual , only the password is for Victron registered installers only
Alexandra avatar image Alexandra ♦ peter-3 commented ·
That is for the more complex and ESS setup. As grid codes need to be set and complied with.
First time set does not need a password but changes to the grid standard after that will need the password. This is done in ve configure so a different program altogether.
But all the basics in Victron Connect are accessible to end users. For your set up this is enough.
