mattguy avatar image
mattguy asked
Extra wires to sense current on lynx shunt
Hey all I had no hits the other day asking about the reference voltage of the lynx shunt. I tried asking Victron directly but got the answer that the lynx shunt uses a range of voltages to sense current. Which doesn't make sense to me, but I'm no EE.
My question is then, does anyone know if it's possible to add an extra current sensing device to the circled locations in the attached photo on the shunt. Essentially using the shunt as a normal 'dumb' shunt for the device I'm trying to hook up? Thanks for any and all help.
lynx shunt
kevgermany avatar image
kevgermany answered ·
Shunts work on ohm's law.
Resistance of the shunt is known. Voltage across the shunt depends on current flowing through it. Circuitry in the unit measures the voltage across the shunt, calculates current and reports it. Hence the varying voltages reply.
It's not clear what you're trying to do but you must have a low resistance/high current draw. You should not connect anything across the internals of the shunt. You risk fire as well as breaking the shunt. If it does continue working, chances are that your actions will invalidate any shunt readings.
mattguy answered ·
Thanks for your reply.
