marklh avatar image
marklh asked
Can I use the MultiPlus-II 24/3000/70-32 GX in the usa safely in grid tie mode? Will I have to adjust the frequency, and voltage limits. What else do I need to set up the grid tie code?
Can I connect my AC input to my pool pump power supply?
charge controller compatibility
Paul B avatar image
Paul B answered ·
if the multiplus II is a 220v version then this will not work in a 110v country when connecting to the 110v grid . There is no such thing as a Grid tie mode for the multiplus II however you can connect grid tie inverters to a multiplus II
