jtk avatar image
Carlo Gavazzi with MultiplusII
Hi All,
Love my system..
A question. I still need to connect my Carlo Gavazzi ET112 to my system. Is the only way to do this through the Mk3 to the VenusGX? No way to connect it directly to the VE.Bus?
MultiplusII, VenusGX, 150/100 MPPT, 2xPylontechUS3000
Thanks
Energy Meter
wkirby avatar image
wkirby answered ·
Hello
No, you cannot connect Carlo Gavazzi through VE.Bus or MK3. Carlo Gavazzi is RS-485 MODBUS, a completely different protocol to VE.Bus.
You need to connect Carlo Gavazzi with a RS-485 to USB interface cable directly to the VenusGX. Also there is Zigbee for a wireless connection if you want to.
RS-485 interface:
https://www.victronenergy.com/accessories/rs485%20to%20usb%20interface
Zigbee radio set:
https://www.victronenergy.com/accessories/zigbee-converters
ET112 manual for connection diagrams:
https://www.victronenergy.com/live/energy-meters:et112
Thanks. It would thus be a normal USB cable with 3 of the 4 wires connected? Or is there some processing happening in the usb plug?
Olease ignore. I see the cable has some circuitry in the connecter. Guess i need to order ine. Will any work or must it be the vitron one?
If you want to guarantee functionality and support, please use the Victron 485 interface.
