cargol66 avatar image
cargol66 asked
How to keep 4S 2P 12V 220Ah Gel Victron batterybank balanced?
Hello Everybody,
As mentionned in §6.3 of this article
https://www.victronenergy.com/media/pg/Manual_SmartSolar_MPPT_100-30__100-50/en/operation.html#UUID-8215391b-0004-2e53-2eb5-521a9c260cf1
Gel batteries are not suitable for equalization charge.
How to keep balanced a 4S2P with 8 Victron Gel 12V 220Ah batteries without performing equalization regularly ?
How should be wired the battery bank? parallel wiring then serie
or
or Serie then parallel
In this second solution, wether batterie balancer should be used, each battery string will need battery balancer
What is your feedback about keeping balanced a serie string ?
Thanks for your replies.
battery chargingBattery Balancer
nickdb avatar image
nickdb answered ·
You really should use battery balancers. You can get by with 3 balancers, it should be documented in the balancer’s install manual.
We have a few installs just like this, works well.
Like this, without the last bank.
cargol66 answered ·
thanks for the wiring schematic. It confirms that batteries should be parallelized before to be serialized.
What about the equalization process for Gel Batteries ? Please could you confirm Gel Batteries should not be equalized and the only way to keep bank balanced is batterie balancer?
Thank for your help.
Regards.
Equalisation is only for specific battery types. Not for Gel. Internal equalisation is automatic from the absorption/float stages of charging.
VictronConnect VE.Bus charging manual
