markt456 avatar image
markt456 asked
MultiPlus-11 12/3000/120-50 2 x 120V Low Battery Alarm Shutdown
Just installed in my 5th Wheel A MultiPlus-11 12/3000/120-50 2 x 120V Inverter, Cerbo GX W/Touch 50, two MPPT 150/85 controllers, VE.Bus smart Dongle, SmartShunt 500 amp Battery monitor, 900AH of battery’s and 2,000w solar. Set up the Inverter with the following setting but keep getting a LOW BATTERY ALARM at 13.29V and the Inverter is shutting down. I looked through the blogs, but all the Inverter setting pages look different than mine.
Any ideas?
The setting method of MPPT and inverter of 12.8V lithium iron phosphate battery pack is as follows:
Charging
Charging Limit Voltage: 14.6V
Over Voltage Disconnect Voltage: 15V
Over Voltage Reconnect Voltage: 14.2V
Float Charging Voltage: 13.8V
Discharging
Low Voltage Disconnect Voltage: 10.8V
Low Voltage Reconnect Voltage: 11.6V
Under Voltage Warning Voltage: 12.4V
Thanks
Mark T
Multiplus-IIlow battery warning
