Is there any recommended brand of LTO 48V battery pack compatible with Multiplus II inverter/charger ?
This is the list of officially supported batteries:
https://www.victronenergy.com/live/battery_compatibility:start
Everything else is DIY. But as far as I know there are some other BMS' that are compatible.
Thanks Matthias,
Please can you confirm if Growatt ARK LV battery can be use with Victron Inverter Charger and Victron MPPT Charge Controller.
Thanks
75 People are following this question.
