campdaily avatar image
campdaily asked
Digital multi control. GX or not?
My system will have a Multiplus, a CCGX & a ve bus Bms. The Multiplus will not be easily accessed. I want to be able to turn the inverter off/on remotely. Can I do this with a Digital Multi Controller plugged into the remote port in the ve bus Bms? If so, do I need the GX version or a standard Digital Multi Controller?
rmcgregor3 avatar image rmcgregor3 commented ·
Hi Campdaily, did you ever get an answer for this? It’s the exact question I have. Thanks Rob
GX or not doesn't matter, it is just the design.
The GX looks like the CCGX. If you want to place them next to each other the GX would look better (and is a bit cheaper).
