I normally run my Phoenix Inverter at ECO-mode, with "Wake-up" set to 15w, but I am running into problems when connecting my pc charger. This charger is consuming less than 15w and this makes the inverter to continue searching and my computer does not charge unless I switch to ON-mode. But I don't want the ON-mode as the running mode as it is consuming too much power when not in use.
Could this be improved in next firmware. Lower the minumum the Wake-up to 5w or something ?
