tiktaalik avatar image
tiktaalik asked
How to wire Orion DC Charger for a single combined Lithium Starter and House Battery
I am fairly new to the Victron Universe and I am in the process of helping someone with a wiring diagram where they want to remove starter battery in the engine bay and replace it with a combined starter/house Lithium battery in the rear of the vehicle. Looking at the two wiring diagrams for the Orion DC-DC charger, this scenario is not included, which is why I am asking for help here.
I’m assuming they would need to follow the Victron Charger Diagram but the starter would be omitted and there would need to be additional battery cables from the starter/aux (installed after the DC Charger)?
The DC Charger can only accept 6AWG cables and for a relocated starter battery the cables from the starter to the starter battery would need to be 1/0 so I am assuming those would need to be run independently of the DC charger?
If anyone has attempted something like this before I would very much appreciate your input.
Thanks!
orion dc-dcwiring diagram
mkeefe237 avatar image mkeefe237 commented ·
Hi. Did you ever get an answer to your question above. I too am currently installing a lithium Ion battery, (Dakota Lithium + 12V 320AH LIFEPO4 DUAL PURPOSE BATTERY with 1000CCA) I was looking at either the (Orion XS 12-12v 50A DC-DC Charger) or (VICTRON ENERGY® ORION-TR SMART 12/12-18A ISOLATED DC-DC CHARGER) I'd prefer to use a chassis ground (Orion XS 12-12v 50A DC-DC Charger). Any help on how you ended up wiring the DC-DC charger would be appreciated.
dc4me avatar image
dc4me answered ·
Depends on what you are starting, be careful with using Lithium for a starter battery.
kevgermany avatar image
kevgermany answered ·
This risks getting to a low house battery/no start situation.
Starter battery should be retained to smooth out alternator fluctuations. What's the reason behind this change?
Victron DC to DC Converters Product Range
__________
