stella avatar image
stella asked
Is grid feed in from battery possible?
Hello, I am Alain.
My system is:
Quattro 10kva, 2 x fronius primo, 48v lifepo4 battery bank 50kwh connected to the grid.
Everything works perfect, as in, the solar that is not used feeds to the grid.
I want the excess solar power stored in the battery to feed to the grid later in the evening.
The reason for this is the compensation I get is highest in the evening.
Somebody out there with a solution?
Regards.
MultiPlus Quattro Inverter ChargergridFronius
pau1phi11ips avatar image
pau1phi11ips answered ·
I take if you have a GX device connected to the Quattro for monitoring?
In Venus OS, you can change the Settings > ESS > Grid Setpoint to a negative value and it will feed back into the grid. You will need to write a script that runs on the Cerbo to change this automatically at certain times tho. You should be able to do it via the DBus.
stella avatar image
stella answered ·
Yes, the CCGX.
For my setup there was no need for the ESS assistant.
So what is the best ESS assistant for this?
paragon avatar image
paragon answered ·
It would be quick and convenient to move the Mains setpoint in the ESS to the negative range.
See picture.ess.jpgDisadvantage of this cheap solution is that this must be manually adjusted every day, so as not to end with empty batteries in the blackout.The better solution would be, of course, that Victron provides a timer in the GX device ;-)
https://www.victronenergy.com/live/ess:quick-installation-guide
