cabadger avatar image
cabadger asked
SmartSolar Batterylife
I have a SmartSolar MPPT 100/30 (firmware v1.59) installed in my camper van. The load output operation mode is set to "batterylife".
How can I see what the active SoC limit has been set to?
I do not have ESS assistant installed because I am never sending power back to the grid - just charging the battery from solar or the alternator in the van. I had the battery shut down recently around 60%, so the batterylife algorithm appears to be having some effect.
I have added a widget to the VRM portal showing "ESS battery life SoC limit (%)", but this only shows a continuous 10% which is where the static SoC limit is set.
batterylife
