moesby avatar image
moesby asked
BSC IP65 12/25 Won't charge
I have a BSC IP65 12/25, it has worked without problems the last 2 years, but now when i connect the 240 volt it goes direct to Absorption charge and it only sends 0.4 amps out for maybe 2 seconds then goes back to 0.0 amps. If i remember correctly it should also connect the white dots with a white line. I have tried to disconnect the charger from the 240v and 12v system for 2 minutes and then reconnect, but that didn't change anything. Any idea what's going on here ???
Pic from the app
https://imgur.com/a/bGCAEhc
error
5 comments
marekp avatar image marekp commented ·
@Moesby
Did you try it with the different, known good, battery?
moesby avatar image moesby marekp commented ·
No, I don't have another 12v at hand, other than the one in my car, and it is fully charged
marekp avatar image marekp moesby commented ·
@Moesby
You say it is fully charged, but your pic shows 11.48V.
So it is either bad battery or bad charger.
Did you try to use it as a power supply?
It is my extra battery that is fully charged, the one that my victron charged is connected to is at 11.48
@Moesby
First you say:
Than you say:
Sorry but you lost me.
