e6bill avatar image
e6bill asked
Use MQTT to enable/disable SmartSolar MPPT
How do I change the "charger enabled" setting via MQTT? I can read and write values, just need to know which topics, if any, need to be changed. My end goal is to enable/disable the MPPT's based on several variables in my RV automation software.
for example:
N/d41243d304cb/solarcharger/277/Mode
N/d41243d304cb/solarcharger/277/State
MPPT ControllersMQTT
elvis avatar image
elvis answered ·
Mode will turn the output on and off
Write 1 for ON
Write 4 for OFF
woogieboogie avatar image woogieboogie commented ·
When I write this value with MQTT explorer I see the value briefly change but then it returns to the original value. So it doesn't seem to be remotely writeable, any idea what I may be doing wrong?
rola avatar image
rola answered ·
You must send the change to
W/d41243d304cb/solarcharger/277/Mode
That worked, thanks.
