alex-2 avatar image
alex-2 asked
Dc generator to charge lithium
Hi
I have a bank of 4 x 100Ah smart lithium, Cerbo, Multiplus, Orion dc-dc 12-12 30 charger between my start battery and lithiums. This works great when engine runs.
I have a 4Kw Fischer Panda DC generator which was linked direct to the original lead batteries. Would this work if I ran it through the starter battery and Orion - the same as the alternator?
Many thanks
battery charging
kevgermany avatar image
kevgermany answered ·
It's way oversized for the Orion, so will be very inefficient. Hopefully the voltage is well controlled under light loads.
alex-2 avatar image alex-2 commented ·
What would you suggest?
The generator came with the boat and I’m moving everything over to Victron. It would be a shame to not have the option of using the generator of I need it, ie cloudy days when I can’t get enough solar.
kevgermany avatar image kevgermany ♦♦ alex-2 commented ·
If the generator voltage and power are within the parameters for the lithium setup, go direct to the BMS after checking cable sizes.
But hopefully someone who knows these generators will offer a better answer.
