Lamberto Lopez Luengo avatar image
Lamberto Lopez Luengo asked
Quattro Charger from ACin2 without external relay
My question is how can I tell my 8Kva Quattro, through the connect application, that I only want to charge through AC In 2 when my battery level is below 20%, and to stop charging when it reaches 50%? , having the ACin 2 connected all the time. Right now I am using an external contactor activated through one of the relays with relay wizard programming, (MK2 and Victron Connect software), but when I close the relay many times the system drops for a few seconds if the load is greater than 3 Kw in ACout.
Thanks in advance.
MultiPlus Quattro Inverter Chargerbattery charging
@Lamberto Lopez Luengo
I just want to clarify here. No charging from ac but donyou want to remain connected to ac?
If you do not then you can just use an ac ignore assistant.
Lamberto Lopez Luengo avatar image Lamberto Lopez Luengo Alexandra ♦ commented ·
Yes, the idea is to ignore the input in AC2in, and to do so use some assistant to charge from ACin2 below 20% of batteries, and stop charging above 40.
Right now I have it done with a Home Assistant integration, a Shelly to be more exact, against a contactor, but I don't like it 100% as it cuts the current.
