The new control mode in VRM no longer shows the inverter control icons. Only shows relay control.
Hi @mike,
Indeed, apologies but the inverter control feature in VRM has been removed.
Work continues on these new control features, but for now that module is no longer available.
EDIT - UPDATE - This feature has returned.
Ich kann mich da nur anschließen! Das war eine super coole Funktion und sie hat zumindest bei mir zu Hause wunderbar funktioniert. Würde mich sehr freuen, wenn sie zeitnah wieder eingeführt wird.
Adding inverter control to the dashbord was a great update. I used it daily, as long as it lasted, and really appreciated the easy way of accessing the control. Removing this useful feature, without even a message in the VRM’s ”What’s new” section, is not appreciated. Removing the inverter controls is really as big change as adding them. Such sudden changes confuse users into believing that something is wrong, since it just dissapeared. Please give us this feature back!!!
This functionality is still available in the Marine MFD app, and as a workaround might suit some.. https://www.victronenergy.com/media/pg/Venus_GX/en/marine-mfd-integration-by-app.html
For those demanding it back. I'm sure it was removed for a good reason and there was a problem with it. I'm sure it'll be back when all the kinks are ironed out.
This was a super feature for us running a off grid cabin. Please give us back the posibilty to switch Multiplus ON/OFF in the VRM as soon as possible!
Please bring it back. Looking at alternatives now on how to do the same controls through MQTT or modbus.
47 People are following this question.
