hobbes avatar image
hobbes asked
Which Victron Inverter(s) Charger should we get for our off grid - solar powered - small holding ?
Our maximum simultaneous AC watts load will be 4800watts .
We will need to run power tools like a chop saw and a skill saw ...
plus a washing machine and various water pumps .
Do we need 2 x Multiplus 3000VA ? (2400watts x 2 = 4800watts)
Or is there a circa 5000 Watt AC output (at 25 degrees) inverter charger available ?
Many thanks !
multiplus in parallel
Alexandra avatar image
Alexandra answered ·
@Hobbes
Because you have "various pumps" and motors mix, I would size bigger at 8kVa Quattro.
It will also allow for future expansion, which is what inevitably happens when you own an inverter - you start to want to add more after a bit.
@Hobbes to add to what Alexandra said. A pump may take up to 6 times normal load when it starts. Microwave ovens are another killer. You need the overhead capacity.
There's an excellent video on YouTube by @Johannes Boonstra (Victron Energy Staff)
on diagnosing inverter overload which explains this well.
https://youtu.be/4SXtGIx0x5w
klandos avatar image
klandos answered ·
I would Start with 2x Multiplus 5000 and the Option to expand, or with one 10k Quattro.
ejrossouw avatar image
ejrossouw answered ·
If you will only have one AC input from e.g. a generator with no grid at all or plans for wind turbines etc. a Multiplus-II 8kVA will suit too.
klandos avatar image klandos commented ·
Keep in mind that you cannot Stack the 8k Multiplus in parallel.
The inrush of various Pumps Could be a problem. Bad if you cannot expand…
