Will the Lynx Shunt VE.Can speak to my Smart Solar MPPT 250/70 Ve. can through Cerbo Gx to monitor Battery voltage and adjust charge? I also have the Multiplus II in the mix.
Regards
Regards
@Johnsmith yes you can. You will need to enable DVCC on the Cerbo with Shared Voltage, Current and Temperature. Here is the reference to the manual https://www.victronenergy.com/media/pg/Cerbo_GX/en/dvcc---distributed-voltage-and-current-control.html
30 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
