michaeltenerife avatar image
michaeltenerife asked
Is it possible to monitor the whole system with Cerbo or an easy solar2 without wireless?
My system is in a sealed container that don't allow any wireless communication.
Is it possible to have a cerbo sending the systems information through a cable to the internet to be accessed?
Is that also possible with an easy solar 2 that has GX incorporated?
Thank you
Bluetooth
Kevin Windrem avatar image
Kevin Windrem answered ·
Cerbo has an ethernet port that can be run out of your box to a router, etc to make an internet connection.
The GX device inside the Easy Solar also has an ethernet port.
michaeltenerife avatar image michaeltenerife commented ·
So the ethernet port can be used for having all data sent how?
Where can I read more about this ethernet port usage?
Thank you
Kevin Windrem avatar image Kevin Windrem michaeltenerife commented ·
The same information can flow via the ethernet port as flows over the WiFi connection. If you are trying to connect to the GUI, any web browser on the same network can make that connection using venus.local as the URL, same as with WiFi.
If the network has an internet connection, VRM will also work.
