Esteban Omar Guisado avatar image
Esteban Omar Guisado asked
Victron SmartSolar 75/15 MPPT with Lynx Distributor - Fusing/Wire Size
I purchased a Lynx Distributor, SmartSolar 75/15 Solar Charge Controller, and a 175W Solar Panel.
Solar Panel to Charge Controller:
*25A Breaker and 10AWG wires
Charge Controller to LYNX:
*40A?? Fuse and 6AWG
I am trying to determine if I can use a 40A mega fuse (smallest that will work in the Lynx) between the controller and the LYNX...
I know that the wire size (6AWG) and length (<4ft) is fine for 40A, but I want to know if there is any other issues/risks with using a 40A fuse instead of a smaller one? Risks to the charge controller?
Can someone let me know if the 40A fuse is ok?
Thanks in advance!
Esteban
MPPT ControllersLithium Batteryfuses
wkirby avatar image
wkirby answered ·
The fuse is only to protect the wiring, so a 40A fuse is adequate for 6AWG wire.
The charge controller does not detect what fuse is installed, so it will work as normal.
MPPT Product Page
MPPT Error codes
Battery Compatibility
Fuses & fuse holders Product Page.
