stuart-houghton avatar image
stuart-houghton asked
Replaced Multiplus 48/5000/70-100 connected to LG RESU 6.4
Five years ago I installed a Multiplus 48/5000 connected to a LG RESU 6.4 battery it all worked well and use the Hub 4 assistant. The unit recently failed and I have replaced it I read that the best assistant to use now was ESS so I set it up as per these instructions https://www.victronenergy.com/live/battery_compatibility:lg_chem_resu There is an AC connected PV system. Now the the CCGX doesnt show the connected PV but the main problem is the battery only charged up to 85% and it will not discharge.
All thoughts appreciated.
LG Chem RESU
