johnny-brusevold avatar image
johnny-brusevold asked
Why does 0.1A not appear in AC power?
Test with load of 0.35A
Trying to learn some python programming, but there's something I do not understand here. Thinking that this must be somewhere else in the code for energy measurement.
When I check with dbus-spy, nothing appears under Amp.
In the program, if I switch to factor of 10, 3.5A is displayed in debus-spy, but only 3.0A in Remote Console.
If I change to a factor of 0.1, 0.035 is displayed in debus-spy and nothing in the Remote console.
Is there anyone who can lead me in the right direction?
Energy Meter
Kevin Windrem avatar image
Kevin Windrem answered ·
It is possible the GUI code is taking only the integer part of the value so anything under 1 amp would show as 0. Most of the GUI code is written in QML and files are in /opt/victronenergy/qui/qml. Within that directory, the files conform more or less to the menu that appears in the GUI. File names for overviews begin with Overview...
I suspect you'll find the parameter in question will be processed through .format(0) which formats the number with no fractional components. If it were .format(1) instead, you should see a value of 0.3.; .format(2) would output 0.35, etc. There are other formatting methods used as well, some automatic or build in to the object. For example a dbus parameter name with .text appended to it may format a number in a way built into the object. I'm not sure where that built-in formatting is written.
johnny-brusevold avatar image johnny-brusevold commented ·
@Kevin Windrem
Thanks for the detailed explanation.
There was no change in the displayed values even though I change the code to the correct value. There is a lot I have to learn first, before I see the whole of this system.
