I want to upgrade to the new firmware, was just wondering if it would reset all my values in the system or will they stay unchanged?
Which device do you want to update the firmware on?
Quattro 48/15000/200-2x100 and SmartSolar charger VE.Can 150/100
When updating the firmware on your SmartSolar VE.Can, the settings are retained. With the Quattro you have to save the settings before the firmware update and restore them after the firmware update because the unit will be reset during firmware update.
Sorry I'm new to this :-(
Check the VRM:Remote VEConfigure document for more details.
And while you read the document about remote VE.Bus firmware updates, makes sure you read about the requirements, especially about your CCGX has a serial HQ1707 or newer, two-communication is enabled and firmware is 2.65 or later. It's in the manual under requirements.
I'm not sure why I suggested to use remote VEConfigure, maybe because you said you have downloaded the remote config files. But for remote firmware update it is as said in my initial post, the Multi/Quattro will reset, which means it will power off and on again and by that will lose all settings.
As long as your GX device is live on VRM, there should be no problem to upload the remote config file again, unless your GX device is powered by the Multi/Quattro.
The whole procedure is described here: https://www.victronenergy.com/live/venus-os:remote_ve.bus_firmware_updates
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
30 People are following this question.
