maringotka avatar image
maringotka asked
What size MPPT charge controller for these batteries?
What size MPPT charge controller for :8-90 watt Zamp 19.1 volt 4.7 amp panels in series/parallel. Four strings of two panels. String volts=19.1x2=38.2 volts. System : 4.712x4=18.84amps
With: 3-Ampre Time 12 volt 300 Ah LiFePo built in 200A BMS.
Plan to add one additional string.
Which Victron MPPT Controller?
charge controller compatibility
Trying to add information about the batteries
Tried twice
I hope the information is there
Here’s the battery information again:
3- AmpreTime 300Ah LiFePo batteries with built-in 200A BMS
Assuming the batteries are parallel and thus a 12V bank, you have about 60A max going into the batteries. A single 100/50 would cover this, charging at 14.4V. Which would bring the current close to the 50Amps limit of the controller. An alternative would be two 100/30s.
maringotka answered ·
What battery monitor is needed.
It will work fine without one, but a good starting point is the BMV 712
Can you provide settings for a novice to program he charge controller?
If you install the victron connect app and select demo library you'll, be able to find the controllers and their settings. The values you need come from the battery suppliers.
I read somewhere that each battery should have its own breaker. Does the Lynx Distributor address this need?
Lynx Distrbutor is a Victron product.
kevgermany avatar image
kevgermany answered ·
It's not necessary. One for the whole bank is enough. I have no knowledge of Lynx.
