what are the derating ratio in the power and the current for the MPPT 100/20 at 50 degrees?
From what I have read, it is linear down to zero at max temps.
The graph will be something like this one.
Thank you Alexandra for your response, but in the datasheet Victorian mentioned that the operating temperature is from -30 to +60 ° C (full rated output is up to 40 ° C), so the Mvader talk is not clear to me or there is information missing
Full power at 40 ° C. no output at 60° C. 50° C is midway so the output is likely 10Amps.
58 People are following this question.
