stavarda avatar image
stavarda asked
Cyrix model required
Hello All
Im looking at building a system with to start with lead acid starter and AGM fo rthe house bank later upgrading to Lithium .
I think i can use the Cyric Ct for Lead acid and AGM /Lead acid depending on what i can find in the far east.
then when i get some Lithiums use teh Cyrix Li Charge.
would i be able to use the cyrix Li charge with the AGM /Acid set up or would it not work.
will i have to buy different units as i upgrade ?
will the Cyrix Ct work with AGM batteries.
Thanks
battery
