muhkel avatar image
muhkel asked
MultiPlus 3000VA 24V Remote On/Off issue
Hi all,
I have problem trying to install simple 3-way switch as a remote On/off/Charger only switch for MultiPlus.
Inverter is turned ON from the original switch.
Shorting H terminals Left-Mid turns Inverter ON
Shorting H terminals Right-Mid seems to be turning it OFF (Maybe goes Charger only mode?)
The problem is: While keeping all terminals open with switching the remote switch in the middle, the inverter is still turned ON.
I am not using any remote panels with the system. I have VE.BMS but the Remote Control port is empty.
What I am doing wrong?
Thank you!
remote console
Paul B avatar image
Paul B answered ·
on the main board there is a remote control blue plug it has three connections its looped from factory on the left to mid as closed - opening this loop Mid to left turns the inverter charger off - looping the mid to right of the plug turns the charger only on
