Which AC (230V) battery charger can be used to charge a 48V Victron battery bank (N.8 Victron battery LFP 200Ah 12,8V - 2 parallel of 4 in series) by AC generator (5000W-230V)?
almost every Victron MultiPlus Inverter/Charger will charge a 48V battery bank. Otherwise I can only think of the Victron Skylla TG series, which has a 48V model as well.
https://www.victronenergy.com/upload/documents/Datasheet-Skylla-Charger-EN.pdf
and just as an example out of many other MultiPlus Inverter/Chargers: https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-inverter-charger--800VA-5kVA-EN-.pdf
Hi, @Stefanie... is there any cheaper battery charger than inverter-charger Quattro-Multiplus or Skilla TG?
Not that I'm aware of, sorry.
It doesn't need to be a Quattro. Depending on with many amps you want to charge your battery bank, it can be a smaller unit. Please see the full product range of MultiPlusses and Quattros: https://www.victronenergy.com/inverters-chargers
Ok @Stefanie, if I want charge the battery bank with 50A there is Skylla-TG 48/50.
Are there any cheaper battery chargers than it?
30 People are following this question.
