coreyzev avatar image
coreyzev asked
How does a multiplus-ii handle large variations in input AC voltage?
Putting a multiplus-ii in my camper. I see many suggestions to use an EMS to protect my camper. I'm considering just using a circuit breaker instead. And I'm wonder how the multiplus-ii handles those variations in input vs its output.
I can see from the datasheet that the inverter I'm using can handle 90-140VAC of input. How is the output AC voltage affected by this? (especially if there's no battery to back it up?) I have seen reports of campgrounds sending out voltage as low as 100V.
Thank you
MultiPlus Quattro Inverter Chargervoltageac
The AC input will be passed through to the output. So the output voltage = input voltage.
You always must have a battery connected.
JohnC avatar image
JohnC answered ·
@coreyzev
Also, the Multi will reject ACIN if not within it's settings. Pardon the 230V/50Hz example, but it looks like this in VEConfig..
