Claudio Paredes Budon avatar image
Claudio Paredes Budon asked
Multiplus II GX with generator, output 2 disconnect when I connect loads.
Hi everyone,
I have a Multiplus II GX with pylontech batteries, when I connect the generator there have good voltage and frequency, it charge the batteries and it's voltage in AC_out_2. The problem is when I connect something to that line, the multiplus disconnect the generator in AC_in and it's don't show any error.
Multiplus-IIGeneratorac out 2
@Claudio Paredes Budon
We had a load on ac out2 that used to do that to the generator. It was a pump control with a neutral earth leak causing the "grid rejection".
Check the wiring.
Paul B avatar image
Paul B answered ·
could also be that the load is two great for the generator and the low voltage cut off is disconnecting the generator reduce the current input limit
