Stephan Doiron avatar image
Stephan Doiron asked
Which DC-DC charger model for use with Ecoflow Delta Max
I'm looking to charge an EcoFlow Delta Max from the alternator / battery.
According to the manual: The product supports 11-100V DC input, 10A max current, and 800W max charging power (link to manual: https://www.powerequipmentdirect.com/manuals/ecoflow-ed59af29b440aad4d4855220fbc82aa6.pdf)
I watched a video where a similar battery system (Goal Zero Yeti) was being charged with a 12/24-15. I've also seen the 12/12-30 on Amazon as I don't have a 24 volt system but the amps are too high? I've seen as 12/12-18 as well but that is also above the 10A listed in the manual. I've done the research but I remain confused...
My question is simple. Can I charge my EcoFlow Delta Max with one of these controllers? If so, which one please? Thanks for your time!
battery chargingdc system
If I read the manual correctly there should be a "car charging port" there you should be able to directly connected it to your car without any additional comments.
Stephan Doiron answered ·
The way you suggest would take 10 hours of driving to charge the battery bank, not realistic. Is there a reason you wouldn't recommend I use the alternator to charge it faster? I'm confused, what am I missing?
There is one DC charging input for different voltage so I guess there is some kind of electronic inside to convert the input voltage/current into a charging voltage/current.
That input seems to be limited to 10A 800W max. To get 800W charging power you need an input voltage of 80V at 10A.
Since this is a Victron community we can't say if it will work with a DCDC converter or not. You should ask the manufacturer of that unit about that.
VictronConnect VE.Bus charging manual
