How can i figure out what inverter is what phase in a three phase system (3x 48/5000/70?
I have full remote access.
Thanks!
Thanks!
Use VE configure to blink the led's on each inverter in turn, this will identify them. However, this is normally a local procedure, I don't know if it can be done remotely.
No, a shut down is not necessary to do this.
you will need a Mk2 /3 interface and the software, then you can flash the leds on a particular inverter to identify it.
28 People are following this question.
