jans avatar image
jans asked
Earthing systems for Multiplus !!
I would like to know if Multiplus II can be installed on different grounding systems e.g. TN-C-S or TT. I understand that the TN-C-S system combines N and PE wires, or this does not cause problems, because the internal relay will not exclude N from the inverter. Does it not matter because it is connected to the ground.
Multiplus-IIinstallationGrounding
Ground, earth and electrical safety
MultiPlus-II Product page
MultiPlus-II Manual
Multiplus-II GX Online Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
