I want calculate a battery life from actual (or average consumption after 1minute) and actual SoC.
But not sure how to calculate with data from two sources which are not sync.
Thank you for any idea and help
I do just that......
I take the current battery SOC and subtract the set minimum SOC and then divide that by the current power (discharging) to arrive at a time the battery is estimated to be flat.
Similarly, you can calculate an estimate for time fully charged.
There was a useful date/time formatter node to add to the pallet to calculate the times. (node-red-contrib-moment2)
Try pasting this to save you some work....
(You probably don't need global variables that I have used in some cases.)
[{"id":"441c6c1cce05ddce","type":"switch","z":"bf1e31f330e69c5c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"-100","vt":"num"},{"t":"btwn","v":"-100","vt":"num","v2":"10","v2t":"num"},{"t":"gt","v":"10","vt":"num"}],"checkall":"true","repair":false,"outputs":3,"x":965,"y":960,"wires":[["d1d3b8bce39a0e3c"],["772d6aa399d12bdb"],["87a61f5ca9c470e2"]]},{"id":"60643f4bafcb4690","type":"change","z":"bf1e31f330e69c5c","name":"< -100 (Discharging)","rules":[{"t":"set","p":"flat-time-mins","pt":"flow","to":"$round(($globalContext('battery-SOC')-$globalContext('battery-min'))*40*60/$flowContext('battery-power'),0)*-1","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$millis()+($flowContext('flat-time-mins')*60*1000)","tot":"jsonata"},{"t":"set","p":"copy-to-display-directly--not-used","pt":"msg","to":"\"<font color=yellow>Battery flat around \"&$fromMillis($millis()+($flowContext('Time-estimate')*60*1000),' [h#1]:[m01] [P]', '+1000')","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":915,"wires":[["862d3e2030d077a9"]]},{"id":"fb9f4fc8b608b486","type":"change","z":"bf1e31f330e69c5c","name":"> 10 (Charging)","rules":[{"t":"set","p":"charge-time-mins","pt":"flow","to":"$round((100-$globalContext('battery-SOC'))*40*60/$flowContext('battery-power'),0)","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"$millis()+($flowContext('charge-time-mins')*60*1000)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":1005,"wires":[["23169a335dabda99"]]},{"id":"09c287effaba2b7e","type":"change","z":"bf1e31f330e69c5c","name":"-100 to 10 W (Idle)","rules":[{"t":"set","p":"payload","pt":"msg","to":"<font color=grey>=== Battery Idle ===","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1320,"y":960,"wires":[["70a751144c40ec0c"]]},{"id":"f2bf967b830e18a7","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":1145,"y":840,"wires":[["a8d7f1c490d6db89"]]},{"id":"a8d7f1c490d6db89","type":"change","z":"bf1e31f330e69c5c","name":"set flow.battery-power","rules":[{"t":"set","p":"battery-power","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1330,"y":840,"wires":[[]]},{"id":"d1d3b8bce39a0e3c","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":1145,"y":915,"wires":[["60643f4bafcb4690"]]},{"id":"772d6aa399d12bdb","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":1145,"y":960,"wires":[["09c287effaba2b7e"]]},{"id":"87a61f5ca9c470e2","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":1145,"y":1005,"wires":[["fb9f4fc8b608b486"]]},{"id":"862d3e2030d077a9","type":"moment","z":"bf1e31f330e69c5c","name":"","topic":"","input":"","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":0,"adjType":"days","adjDir":"add","format":"[<font color=yellow>Battery flat around ] h:mm a (ddd)","locale":"POSIX","output":"","outputType":"msg","outTz":"Australia/Melbourne","x":1600,"y":915,"wires":[["70a751144c40ec0c","5a6703fd90ea2abf"]]},{"id":"23169a335dabda99","type":"moment","z":"bf1e31f330e69c5c","name":"","topic":"","input":"","inputType":"msg","inTz":"Africa/Abidjan","adjAmount":0,"adjType":"days","adjDir":"add","format":"[<font color=green>Battery full around ] h:mm a (ddd)","locale":"POSIX","output":"","outputType":"msg","outTz":"Australia/Melbourne","x":1600,"y":1005,"wires":[["70a751144c40ec0c","19b1c41801612f0e"]]},{"id":"239ce9df032664ff","type":"smooth","z":"bf1e31f330e69c5c","name":"~ 15 sec average","property":"payload","action":"mean","count":"11","round":"0","mult":"single","reduce":true,"x":750,"y":840,"wires":[["441c6c1cce05ddce","f2bf967b830e18a7"]]},{"id":"72545a6ec8a2a8c5","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":575,"y":840,"wires":[["239ce9df032664ff"]]},{"id":"ad02e7180b796eb7","type":"victron-input-battery","z":"bf1e31f330e69c5c","service":"com.victronenergy.battery.socketcan_can1","path":"/Soc","serviceObj":{"service":"com.victronenergy.battery.socketcan_can1","name":"BYD Premium LV battery","paths":[{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Soh","type":"float","name":"State of health (%)"},{"path":"/Info/MaxChargeVoltage","type":"float","name":"CVL - Charge Voltage Limit (V)"},{"path":"/Info/MaxChargeCurrent","type":"float","name":"CCL - Charge Current Limit (A)"},{"path":"/Info/MaxDischargeCurrent","type":"float","name":"DCL - Discharge Current Limit (A)"},{"path":"/Alarms/CellImbalance","type":"enum","name":"Cell Imbalance alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeCurrent","type":"enum","name":"High charge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighDischargeCurrent","type":"enum","name":"High discharge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/InternalFailure","type":"enum","name":"Internal error alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeTemperature","type":"enum","name":"High charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/LowChargeTemperature","type":"enum","name":"Low charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"}]},"pathObj":{"path":"/Soc","type":"float","name":"State of charge (%)"},"name":"","x":170,"y":705,"wires":[["09dc839d87f22b25"]]},{"id":"09dc839d87f22b25","type":"rbe","z":"bf1e31f330e69c5c","name":"Block unless value changes","func":"rbe","gap":"","start":"","inout":"out","septopics":false,"property":"payload","topi":"topic","x":540,"y":705,"wires":[["0e5468367619f8e3"]]},{"id":"0e5468367619f8e3","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":845,"y":705,"wires":[["b903bc215cbd7a69"]]},{"id":"b903bc215cbd7a69","type":"change","z":"bf1e31f330e69c5c","name":"set global.battery-SOC","rules":[{"t":"set","p":"battery-SOC","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1060,"y":705,"wires":[["c4bad64373a5433f"]]},{"id":"c4bad64373a5433f","type":"change","z":"bf1e31f330e69c5c","name":"set topic: Battery SOC %","rules":[{"t":"set","p":"topic","pt":"msg","to":"Battery SOC %","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1310,"y":705,"wires":[[]]},{"id":"0a90f2a7c0f5e204","type":"victron-input-battery","z":"bf1e31f330e69c5c","service":"com.victronenergy.battery.socketcan_can1","path":"/Dc/0/Power","serviceObj":{"service":"com.victronenergy.battery.socketcan_can1","name":"BYD Premium LV battery","paths":[{"path":"/Dc/0/Voltage","type":"float","name":"Battery voltage (V)"},{"path":"/Dc/0/Current","type":"float","name":"Current (A)"},{"path":"/Soc","type":"float","name":"State of charge (%)"},{"path":"/Dc/0/Temperature","type":"float","name":"Battery temperature (C)"},{"path":"/Alarms/LowVoltage","type":"enum","name":"Low voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighVoltage","type":"enum","name":"High voltage alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/LowTemperature","type":"enum","name":"Low battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Alarms/HighTemperature","type":"enum","name":"High battery temperature alarm","enum":{"0":"No alarm","2":"Alarm"}},{"path":"/Soh","type":"float","name":"State of health (%)"},{"path":"/Info/MaxChargeVoltage","type":"float","name":"CVL - Charge Voltage Limit (V)"},{"path":"/Info/MaxChargeCurrent","type":"float","name":"CCL - Charge Current Limit (A)"},{"path":"/Info/MaxDischargeCurrent","type":"float","name":"DCL - Discharge Current Limit (A)"},{"path":"/Alarms/CellImbalance","type":"enum","name":"Cell Imbalance alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeCurrent","type":"enum","name":"High charge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighDischargeCurrent","type":"enum","name":"High discharge current alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/InternalFailure","type":"enum","name":"Internal error alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/HighChargeTemperature","type":"enum","name":"High charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Alarms/LowChargeTemperature","type":"enum","name":"Low charge temperature alarm","enum":{"0":"No alarm","1":"Warning","2":"Alarm"}},{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"}]},"pathObj":{"path":"/Dc/0/Power","type":"float","name":"Battery power (W)"},"name":"","x":170,"y":840,"wires":[["72545a6ec8a2a8c5"]]},{"id":"70a751144c40ec0c","type":"ui_text","z":"bf1e31f330e69c5c","group":"bba5452f.7c7ed","order":11,"width":7,"height":1,"name":"Time till flat or charged","label":"","format":"{ {msg.payload}}","layout":"row-center","x":1870,"y":960,"wires":[]},{"id":"5a6703fd90ea2abf","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":1865,"y":915,"wires":[[]]},{"id":"19b1c41801612f0e","type":"StatusUltimate","z":"bf1e31f330e69c5c","name":"Status","property":"payload","x":1865,"y":1005,"wires":[[]]},{"id":"bba5452f.7c7ed","type":"ui_group","name":"Battery","tab":"263714fe.0cdaa4","order":5,"disp":false,"width":"15","collapse":false},{"id":"263714fe.0cdaa4","type":"ui_tab","name":"Solar Status","icon":"battery_charging_full","order":1,"disabled":false,"hidden":false}]
29 People are following this question.
