I want to set up a Multiplus 48V 3000VA 35A as a DC coupled ESS in the Philippines and do not intend to feedback to the grid. What grid code should I select? Appreciate your guidance.
If you do not intend to feed back to the grid then you don't need a grid code. Put another way, you should not enter a grid code if you don't intend to feed back.
Also, if there is no appropriate grid code for your country then you have another reason to not select a grid code.
He wants to use ESS, so he must set up a grid code. It can be "Other", if the specific country is not available and none of the other grid codes would work for some reason.
I can't say if "Other" (or the grid code from another country) is allowed in Philippines or not.
@henry-co
You can set the grid code only once. After that, if you want to change it, you will need a password. You can ask your Victron distributor for that password.
25 People are following this question.
