bcg1976 avatar image
bcg1976 asked
Constant current charging for NiCd block batteries
I'm running a multiplied 24/3000/70 and an MPPT 250/100 and have constructed a 20 battery saft SMB277-2 bank in a parallel/serial config to give me what should be around a 540Ah battery at 24 - 30v.
As I understand it, these sized batteries want around a 50A current constantly applied with a voltage ideally at 1.4v per cell.
Is there any way to reasonably achieve this with the victron kit I have? The batteries owe me nothing besides a headache when I need to get rid of them so I'm not too fussed if we shorten their service life with a good enough solution.
Thanks.
battery charging
snoobler avatar image
snoobler answered ·
Datasheet on this page:
https://www.saftbatteries.com/products-solutions/products/block-nickel-batteries-sble-sbm-sbh
0.1-0.2C5 rate
1.45-1.70V/cell absorption
1.40±.01V/cell float
kevgermany avatar image
kevgermany answered ·
You'll overcharge with your solution. Apart from current, you must cut out when the voltage drops.
bcg1976 answered ·
But is there a way to get current constant on the multiplus? Or at least change the current / voltage curves to something more nicd friendly?
