Your thoughts please? Could I do this charging setup?
![Figure 7: Two Batteries in Series, Two Chargers](https://www.batterytender.com/site/batterytender/images/series7.gif)
Figure 7 shows two 12 Volt batteries connected in series. The resulting battery pack voltage is 24 volts. As you can see, each battery is connected to a single 12-volt charger. This is probably the best way to ensure that each battery is completely recharged to its full capacity after each time that the battery pack is discharged. This eliminates most of the problems associated with cycling batteries connected in series strings.
https://www.batterytender.com/connecting-batteries-chargers-in-series-parallel
section 7
