I'm changing my 4wd setup from ctek to victron. Is there an option to charge start battery once aux batteries are full like the ctek?
Are you using an inverter set up?
Some models have trickle chargers built into them. Particularly the 12 and 24 volt ones.
Otherwise there are automotive chargers.
So depending on where you want to charge from, (battery to battery, grid to battery or inverter to battery) There are many options.
The automotive brochure is a neat place to start with ideas and products for setup.
30 People are following this question.
