dray22 avatar image
dray22 asked
MPII - Charge Temp Limit For Lithium - Venus GX Temp prob
I have only one temperature prob hooked up to my Venus GX. If I enable the new option "stop charger below" for the MPII, will it use my GX temp for shutting down the charge if the batteries get too cold? The builtin temp prob in the MPII will normally show -453 in VRM portal because nothing is hooked up to it. Can you pick what prob it uses?
Venus GX - VGXTemperature Sensor
Paul B avatar image
Paul B answered ·
As far as I know the temp prob that comes with the multiplus II should be connected to Multiplus II T.Sense connection then then the battery - this would then stop charging at the set temp
