aglowack avatar image
aglowack asked
Using the 500amp Smart Shunt with a starting motor battery
I have a simple question that I want to verify. Just purchased a Lithium starting battery for my boat and also purchased the 500amp Smart Shunt. The question is, should the cable coming from my outboard be connected to the load side? I assume the answer is yes, I checked the CCA requirement for my motor and it's only 400amps. Thanks in advance
Lithium Battery
wkirby avatar image
wkirby answered ·
If you are intending to count the energy from the outboard alternator for this battery, then yes, you need to connect it like that.
400A should be fine for a 500A shunt, besides, it is a really short burst for starting.
Nev avatar image
Nev answered ·
As wkirby mentioned, yes.
Our Canter based motorhome has a 500A SmartShunt monitoring all current through our 4 cell 300Ah LiFePO4 including the 3.9l TD starting current that has recorded a peak of 730A but only for a fraction of a second.
Your outboard start current will be a breeze for your SmartShunt.
