casper avatar image
casper asked
Can 1:1 setup work if additional MPPT controller is used?
I would like to know if the following setup is possible:
1 x Multiplus II 5kW
1 x Fronius Primo 5kW connected to ACout
1 x Victron MPPT (3kW pv array)
Can the 1:1 ratio be applied here even though the total PV power would be around 8kW?
Advantage of this setup is that the MPPT charger can kickstart the battery bank back i to life if the are depleated. If only an AC coupled system was used, the system would not be able to start up again without a generator or mains if the battery bank was depleted.
Multiplus-IIMPPT ControllersFronius
marekp avatar image
marekp answered ·
@casper
1:1 rule applies only to the AC coupled PV inverter
