rob-s avatar image
rob-s asked
temperature offset in victron connect with victron 200ah smart batteries
when checking battery temperature with victron connect, batteries indicate a 38-43 F degree offset. I reset to default (0 degrees offset) and they quickly go to the 38-43 F degree offset. The BMS allowed the batteries to charge when the actual battery temperature was 22 F degrees. I have the latest update for Victron connect, have reloaded the app. and nothing is fixing the problem.
temperature compensation
kevgermany avatar image
kevgermany answered ·
Please contact your dealer.
rob-s avatar image rob-s commented ·
If the dealer/distributor had knowledge of this bug, I would not have asked the community for help.
nickdb avatar image nickdb ♦♦ rob-s commented ·
It’s not about the dealer knowing or not, they are responsible for support and escalation to victron, so in the absence of an answer from the volunteer community, it is still the official way to get help.
