@Jean-Luc T. no problem at all connecting the Orions in parallel. I installed two 24/12-30's in parallel a couple of weeks ago, I used the remote's to give me the ability to run 1 or both.
Cheers
Wayne
No, you can use a common bus, in my case i have two power lockers and I ran a single cable from the start battery and split where I mounted the two units, the 12v output you can see the two feeds go into a twin fuse block then connect to large pos bus that goes back to the house batteries.
24 People are following this question.
