pan-mad avatar image
pan-mad asked
Stuck in storage mode multiplus ll gx 24/3000
Hi all. Last night @3am my Multiplus went a bit weird in so far as it dropped out of waiting to charge after a daytime discharge and went into storage mode with a 90% SOC left. The sun is now beaming on panels but not charging batteries nor suppling grid as per ess.
whats may be going on
id 102c6bc29790
storage
Alexandra avatar image
Alexandra answered ·
@Pan-mad
Check your settings on the grid charger tab, if storage mode is checked then uncheck it. In an ESS system it should be disabled.
pan-mad answered ·
Thanks, i did check and i was enabled! I assumed the this was part of the charging cycle when the Multiplus was in charge only mode but still uses the MPPT excess to feed the grid.
Strange how it literaly just “shuts down” and goes what i can only describe as a standby mode even on a full sunny day.
