Any pointers how I could eliminate the problem?
Many thanks
johnny
Many thanks
johnny
Interesting issue.
Have you tried adding some sheilding to the system or a ferrite bead or sleeve onto the cable?
Or check the batteries in the remote for the locking system?
Hello @Alexandra,
Thanks for your reply. Yes, the first thing I tried was checking the remote locking system batteries and after confirming they were good, the testing showed the VE.Direct to USB interface as the problem.
I have tried shielding the electronics portion (that little pod-part) of the cable with a few layers of aluminum foil, and that has made a huge difference! The range and reliability of the remote is just about back to normal.
Thanks for the idea of a ferrite bead/sleeve. I'll try to get hold of that and do some more testing.
29 People are following this question.
